I hope someone can help me. Last night after a power cut the hot water seems to be permanently on. The timer unit 715si, appears to be working correctly, screen visible etc, and the central heating seems to work fine, i.e when the red light is on the rads warm up as they should and the thermostat works ok with the RX1 unit i.e I can hear the RX1 unit click on and off when I change the the temp settings. However when the red lights are off for both hot water and central heating, the boiler is still active and continues to burn on and off with what I assume to be the hot water temp, know this because the bathroom radiator is continually hot. Any ideas what the problem maybe?
Thanks in advance.
Thanks in advance.
