- Joined
- 27 Jan 2008
- Messages
- 29,157
- Reaction score
- 3,571
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Even in Wales, it is unlikely the plumber would need to register his work, however what Part P does do, is make it easier to prosecute when work is not safe.
However the question is why did the thermostat fall off the wall, did he not replace screws, or did some thing break? I have had old plastic units where the plastic has degraded and after being disturbed the plastic has failed, it would be near impossible to show it was the fault of the person working on the device where the plastic latter failed.
Although the BSi/IET BS7671 regulations state we should inspect and test all electrical work, that book is not law, it can be used in a court of law, but it's not law.
So you have to prove the guy was negligent, which is very hard, even before Part P there have been Court Cases where some one has died, and the HSE is called in to investigate. And they have decided who to blame, however it is not always the result we expect. In the one linked to there were three people who could have been blamed, the plasterer who damaged the cable, the plumber who failed to glue pipe, or the guy using tester who fudged up the results, however court cleared them all, and it was the foreman who had not even been on site who was blamed, as he used some one who he knew was not qualified.
So you knew the plumber was not qualified, as you say he said he had an electrician friend who would sign it off, so just like the foreman you knew he was not qualified, so in real terms not sure you would want to take him to court, I don't think the court would totally blame you, but they may put a proportion of blame on you for employing some one you knew did not have the skill required.
OK new pre-warned you would be careful in the way you worded things, "reasonable" is the key word, it may be the plumbers fault, but could he have foreseen the thermostat falling off the wall, had your daughter been killed so HSE got involved, would his actions be seen as reasonable?
I had a new roof fitted to garage, in doing so they damaged the supply cable, with a freezer in garage I needed to find fault and repair it quickly, so I went around removing sockets and fuse connection units to trace fault, I found it and replaced cable. However when I came to inspect and test, I found the builder who replaced the roof, had removed a socket leaving it dangling on the wires, I am sure he was trying to help, however I was unaware it had been removed. So if I had failed to find it, and some one had been injured, who would you blame? Builder or me? I would say me, for not checking, and this is your problem, if there were signs that the job was not to standard, you should have got it corrected or switched it off, you were just as qualified as the plumber.
I know it's not what you want to hear, and I agree the plumber did a poor job, and if you need to get an electrician to correct the work, then yes you should be able to claim it back from Plumber, however I know I would make it safe before calling an electrician, so the electrician if asked was it dangerous would have to say no, as I had made it safe. I would want to give the Plumber a piece of my mind, however don't think I could really do any more, as by time I had found Plumber it would be safe again.
