Darkening white patches in oak fire surround
2 Oct 2007
I've got a oak fire place surround that before I purchased what treated with oil its not laquared. There are some large white strips / patches in it the wood that are very noticable as its on the joins, I know this is 'natural' but it doesn't look great and I want to make it less visable, it doesn't need to be a perfect just something to take the edge off it, whats the best way to do this and darken the white bits ?
cheers
if its opaque[foggy see through] then it may be wood glue smears if its on a join line
if so you need to remove the excesive glue smear
Thanks, but it's defo not glue its the wood, I think someone mentioned it could be the 'sap' part of it but I don't know to be honest.
Sound like its sap wood, should have been cut off and put in the scrap on a decent bit of joinery. You may be lucky staining it but it will always show as the sap wood is not as dense as the hartwood.
Jason
the repro-antique bodgers approach might be useful. get hold of some watercolour paint, even a kids poster paint set will do, and mix a really watery wash of a colour that makes up the difference - trial and error helps here, put some on and if its too brown or too yellow wipe it off and adjust the mix. make sure that its watery, with just a drip of pva in it, so that you need to apply a couple of coats to build up the colour (that way you can blur the edges so they arent so noticeable). I imagine that raw umber, and burnt umber are the colours you will need, perhaps a bit of white and a creamy yellow.
if the white patches are from where the wood hasn't been exposed to light, say under some removed beading, then the colours will even out anyway, but this paint trick will not be too extreme to cover the difference while you are waiting.
There are some ways of adjusting the colours of woods such as oak using potassium Bichromate, (an oxidising agent that ages the wood really quickly) or a vapour bath of vinegar and iron (put a cup of vinegar with some nails in it inside a polythene shroud over the wood for a few days. these are both fairly specialised tricks that are a bit over the top for your problem, I've mentioned them in case you want to try searching for the techniques.
As the surround has already been oiled neither of the two above waterbased methods will work. You will need to sand back to remove the oil and then try a spirit stain to colour the sap wood. And the fuming/chemical treatments will darken all the wood not just the light areas.
Jason
