Daylight factor calculator
16 Apr 2004
Anyone know of a calculator for Average Daylight Factor. I've got the formula but some Excel wiz kid must have made up a spread sheet for it somewhere.
The formula is DF = MWuT/A(1-R^2 )
Where:
W = total glazed area
A = total of room surfaces
R = reflectance of room surfaces (default is 0.5)
M = correction for dirt factor (1.0 for normal accessible windows)
T = glass transmission factor (0.6 for low-e double glazing)
u = angle of visible sky (default is 65°)
I've tried to work up a spreadsheet but I keep getting weird results and I can't work out where I'm going wrong. It's giving me daylight factors of 0.7 to 0.8 for fairly standard window sizes. The minimum specified by code for sustainable homes is 1.5% for living and bedrooms which means I'd have to double the size of the room windows to comply. Which doesn't sound right to me.
I've had a go, but with no test data to put in I'm not sure it works as it should.
Here's the link (google spreadsheet).
Could you give me some units and test data?
John, This subject is not our field, but we came across this link a while ago.
It's in old money but have shuffti. If it is not what you are seeking, sorry.
oldun:cool: :cool:
Daylight Factor Calculation Tool Version 1.01
File Format: Microsoft Excel - View as HTML
The spreadsheet tool uses fundamental algorithms and has been bench tested against ... To see grid points with similar daylight factor values, press the “Do ...
www.msbg.umn.edu/downloads_v2_1/5IEQ_App-I-3_V2-1.xls - Similar:cool:
Steve, spot on. Using a random example your sheet gets a factor of 1.26 where mine gets 0.7...odd
Looking at your spreadsheet formula I can see that I had a pair of brackets in the wrong place.
Thanks for that. I owe you one.
oldun. Thanks for the link. As you can see, thanks to stevehuws, I think I'm sorted now.
Dear Sir,
I am looking for the formula to calculate the daylight factor (not the average one but the real one). If I go to the link and I download the sheet it doesn't work... :/ could you help me please?
Do you steal have it?
Best regards.
Nicolas
Hi, is this link to the wrong google doc? This spreadsheet doesn't contain avg daylight factor formula.....
