dead battery?
14 Feb 2011
Hi
I've had to jump start my Dad's car (Renault Clio 1996)every time I have gone to start it (3 occasions). I have driven approx 30 miles after jumping it on each occasion bur when I try to start it a few days later it is dead. Do I replace the battery or could the alternator be mal functioning?
Appreciate any help.
There's a very good chance the battery is goosed - do you know how old it is?
However, if the alternator is below par, the best battery in the world won't last long without being recharged. A basic test: with the engine running, lights and HRW on, the battery voltage should be very near to 14.5v. Can you test this with a multimeter?
John :)
Thanks John
original battery in car never changed (mileage 70000). car is idle for long periods. I have multimeter and will try as you suggested. What is HRW?
Cheers
Heated Rear Window, mate - its best to test the alternator output under a heavy electrical load.
Original battery? It should be framed and mounted on a wall :p
John :)
16 yo battery, that's not bad going!
If you were nearer you could borrow my CTEK MSX 5.0 changer after I've finished with it!!
It may just bring the battery back to life.
