We have a Honda Jazz which spent the first 4 years of its life on the seafront in South Wales. Consequently it has been subjected to an extraordinary amount of rain and sea spray. My wife was complaining that the brakes were vibrating. I jacked it up to take a look. Had a job getting the wheel off as both the nuts were sized and the rim was seized to the hub. The discs were in pretty bad shape, I checked the run out and it is 0.15mm so way out of range.
The hub, upright, shock, everything is coated in rust. I took a wire brush to the hub and re-fitted the wheel with some copper grease on the flange. Pads and discs definatley need replacing but I am wondering what to do about the rest. Is it worth getting some rust remover and wire wool and stripping / cleaning everything up? Then maybe a coat with Waxoil? What about the exhaust which is also rotten?
The clip which holds the ABS wire in place is so corroded the nut has flared open like and onion skin. Will replace that.
Is it worth trying to clean up and protect the rest? Feel like should chop the car in but it has low mileage and FHSH and I don't think we could swap for an equivalent car.
