Good point about the supplier side of things, I read an article a while ago which went into this in detail, about noise polution on mains.
I have experienced many speaker cables, interconnects in the time I have been interested in hi fi, and I can say that they do make a difference.
They will not make a poor system better, but will optimise what you have.
quote:
I admit that if you have a powerful system then "bell wire" would be of little use, but that is because it is too small for the current it will carry, it has nothing to do with sound, since sound is created by the movement of a cone going backwards and forwards (in speakers it is)
I trust by the above statement you are not saying that sound wise bell wire is just as good as a cable costing more, the type of speaker cable used will make an impact on the sound.
quote:
do me a favor (if you can) open an amp, (unpugged of course) how big are the cables that connect to the terminals / plugs that you connect your speakers to to (Mine is all sealed up)
Unfortunately, as I have not had my amp that long, I wouldnt want to invalidate the warranty by opening it up, but it is known that there is also a difference in the cables used that connect to the terminals, depending again how much you spend on the amp.
I can see where you are coming from on the above matter, but again, different cables will have different effects on what you ultimately hear, it has nothing to do with the hifi industry misleading people, I dont know what kind of system you have, but go to a hifi dealer and loan a couple of runs of speaker cable from different manufacturers at different price points and compare, you may be surprised.
Bill
