Installed this system over the weekend. Works a treat and does exactly what it says on the tin. £200 all in all for the Home Premium system with additonal PIR, Door contact and keypad.
Everything worked apart from the keypad. Keypad could arm both home and away but could not disbale the alarm when count down triggered on entry.
So sent the unit away for replacement and got a quick turn around and received new key pad today.
So, just in case there are any tricky methods or so for deleting previous devices, I thought best to post here first as I have certainly been reading this forum a few weeks now and seen good posts from Yaleguy.
So Yaleguy I guess you are best placed to answer this, for deleting a 'device' and replacing it with my new working 'device' (hopefully), is it just simply > programming > edit/add device then select the previous key pad and just delete it?
Thanks in advance.
Thanks in advance.
