Deltabell plus external psu
16 Nov 2017
Hi all, my first post and I have searched but couldn't find the right answer.
I have fitted a pyronix wireless alarm system and have bought the deltabell plus bell box for the backlight function.
I know the bell box has a battery and also can be powered by a 12v supply but does it need to be from the control box?
I was going to run a 12v supply in my loft to power the box. And still trigger it wirelessly.
Can this be done? Will the battery be ok if powered with the PSU?
Can someone also confirm the led jumper position to have the comfort LEDs flashing on the deltabell plus.
I read on another post the link is connected to disable but the manual with the bellbox shows it fitted to enable the flashing LEDs.
Thanks.
16 Feb 2011
Sheffield
How are you going to trigger the bellbox ? You will need a wire from the panel....and a psu for the backlit box
16 Nov 2017
It's triggered wirelessly. I have the non backlit version just now and that works fine just replacing it with the plus version.
16 Nov 2017
No I'm not now, I thought the plus was the same as the deltabell-we with back light etc.
If not then it's my mistake and will have to return it.
16 Feb 2011
Sheffield
You only have to think about it .....how long is that battery going to last lighting up a bellbox ? Only way possible would be a psu in the loft connected to a lightbox ( the delta x had the light box insert) not even sure if they make that anymore ?
16 Nov 2017
To be honest it's only running something like 6 led lights at night so not very power hungry.
That's fine has been my mistake don't know how I could have missed that as read a bit about the plus box aswell.
Thanks.
16 Nov 2017
Does the enforcer panel have enough power to power the deltabell plus?
Or is it better with a seperate small psu and just the wires to trigger it?
I will try and see if I can run the wiring for it and if I can than problem solved.
Thanks.
17 Feb 2017
Yeh the Enforcer can power 1 x Deltabell plus.
16 Sep 2007
That's quite power hungry for something if it were battery operated. 6x LEDs is about 0.3W, so 2.4Wh a night! Your average AA battery stores somewhere in the region of 3Wh.
16 Nov 2017
Thanks for that, learn something new everyday. Can see how the battery wouldn't last.
