hi to all i need some help can i come straight from my footings with solid 225 mm concrete blocks im building my owm extention as our builder took our £7500 deposit and has never been seen again
i'm not aware of the particular type of construction that your architect has specced. i apologise
i agree that you can beef up the insulation from inside or from outside by using thick dense insulation boards, but why bother. it makes any fixing to the walls, later on, rather difficult.
if you insulate from within a cavity then you free up the outer surface of the walls for any fixing that may need doing later on. if it were a kitchen extension then you may find fitting a kitchen to these walls a pain in the ass.
I agree with Noseall re fixings as I have to use rather long fischer fixings when I come across an 80mm thermal board and then it is only going into a soft thermal block.
Most bc,s expect engineering bricks or trench blocks to dpc well that is my exp in Greenwich.
Pete
Hi
You have poured your concrete and you want to build your walls?
A concrete block laid flat is 225mm
laid on edge, as it were, is 100mm wide when looked down upon.
does this help?
ciao
