Well I have to say that this seems to me to be an excellent way of descaleing the heat exchanger, my son has an older combi boiler that works just fine but the flow of hot water is woefully slow, I guess its all scaled up, so Im going to try a DIY descale along the same lines as yourself, Can you tell me though, was there enough water presure to allow the boiler to fire up and heat the water or did you use the mix cold? I was thinking about useing say Washing Machine hoses to connect up to the boiler and I have one of those small drill powered pumps to circulate the de-scale mix, but I doubt it would be powerfull enough to fire up the boiler, perhaps I will use an electric kettle as a heater tank??, anyway many thanks for the tip and the photo, its got me thinking the problem through and Im sure its not going to be too difficult.
Steve.
