I think you might be confused. The LEDs do not show the temperature of the DHW but of the water circulating through the heat exchanger, which heats the incoming cold water from the mains. The temperature of the DHW is controlled by the LH dial. Ariston advise setting it to the middle of the range. Heating the water to 60C and then mixing with cold water to bring it down to 40C for a shower is pointless; just heat the water to 40. It's different if you have a hot water cylinder with hot water stored for several hours, you do need the water at 60C to prevent legionella contamination.It's still showing 60 on the led's. I assumed the boiler thermostat would restrict it to 60?
According to the Installation Manual, the DHW temperature is 36C-56C, depending on incoming water and the position of the LH dial
