- Joined
- 1 Jul 2015
- Messages
- 99
- Reaction score
- 8
- Country
Does anyone own one, or have any views on them?
http://www.dilog.co.uk/_cm_DL6507.htm
Yes, I have one of these. Different brand but exactly the same and even cheaper.
http://www.test-meter.co.uk/tm-el9809-earth-leakage-clamp-meter/
It's fine. Better spec than some dearer ones.
It is. However, I presume his point relates to the description of these devices (e.g. in the link you provided, and the title of this thread). they would only be usable for measuring 'earth leakage' if only the earth conductor (or L & N but NO earth conductor) went through the clamp - which is often going to be quite difficult to arrange.Not sure of Bernard's points. It's a clamp meter; that's how they work.
Not really.thanks for posting EFLI. Thats good to hear and as you say, cheaper again! I have heard some people say they can get bum readings from nearby cables (such as the vast amount inside a CU) - is this something you have noticed?
I don't really understand what you're saying. It will only measure current in whatever conductors are 'within the clamp', and will give you the 'vector sum' of the currents in whatever conductors are in the clamp. With a 2-core (L and N) cable, that 'vector sum' would be the difference been L&N currents - hence probably 'earth leakage'. With 3-core cable (e.g. T&E) it would be the difference between L and (N+'E') currents. As bernard says, that would mean that the displayed 'vector sum' would again be the 'earth leakage' if the leak were 'direct to earth', but if (as much more commonly) it were an L-CPC leak, then it would read zero, since (N+CPC) current would be equal to L current.Not really. Not an expert but if it only measures the current inside the clamps how could that happen? Wouldn't that mean it would give a reading if you just poked it in the CU without clamping any wires?thanks for posting EFLI. Thats good to hear and as you say, cheaper again! I have heard some people say they can get bum readings from nearby cables (such as the vast amount inside a CU) - is this something you have noticed?
Quite. Nor is anything else.My point was that a clamp meter is no use at detecting earth leakage when clamped round length of twin and earth.
I didn't know how knowledgeable bubachuba about the use of the item.
That's what they are called.As it appears to be sold as an "earth leakage detector"
Well, I suppose it would but not if you know what you are doing.one could be forgiven for thinking it would detect earth leakage currents when clamped around a twin and earth cable. ( some years ago an "electrician" did just that ).
Yes, but that's not how they should be used.Clamped around twin and earth it would indicate un-balance ( Live - Neutral ) if the leakage was directly to Ground and not to the CPC.
But bubachuba said he had heard that this model could be affected by other wires outside the clamp.I don't really understand what you're saying. It will only measure current in whatever conductors are 'within the clamp', and will give you the 'vector sum' of the currents in whatever conductors are in the clamp. With a 2-core (L and N) cable, that 'vector sum' would be the difference been L&N currents - hence probably 'earth leakage'. With 3-core cable (e.g. T&E) it would be the difference between L and (N+'E') currents. As bernard says, that would mean that the displayed 'vector sum' would again be the 'earth leakage' if the leak were 'direct to earth', but if (as much more commonly) it were an L-CPC leak, then it would read zero, since (N+CPC) current would be equal to L current.Not really. Not an expert but if it only measures the current inside the clamps how could that happen? Wouldn't that mean it would give a reading if you just poked it in the CU without clamping any wires?thanks for posting EFLI. Thats good to hear and as you say, cheaper again! I have heard some people say they can get bum readings from nearby cables (such as the vast amount inside a CU) - is this something you have noticed?
I didn't know how knowledgeable bubachuba about the use of the item. As it appears to be sold as an "earth leakage detector" one could be forgiven for thinking it would detect earth leakage currents when clamped around a twin and earth cable. ( some years ago an "electrician" did just that ).
I don't know, then.You would think so wouldn't you, but i have heard other sparks claim that this does happen when in close proximity of other loaded cables which is one of the reasons of me asking about this particular model: I wondered if the more expensive models (like the Kewtech 2434) were less suscepticle to such allegations!Not an expert but if it only measures the current inside the clamps how could that happen?
