Diaphragm replacement on biasi 24s
Yes that's the one pull that clip off which will leave the switch hanging connected , turn your boiler on with tap running and stick a screwdriver in the hole in the plastic box and tell me what the boiler does
They say a picture says a thousand words so that is what my boiler looks like
Can we continue this tomorrow night as I feel I’m getting somewhere now ?
Just took micro switch off turned on hot tap , pushed screwdriver into switch and nothing ? So could this be the fault ?
Yes that’s the one , I’ve downloaded the same one when I first noticed the problem
So Not the diaphragm then ;) try buying a switch instead and u don't have to strip boiler parts either
Thanks but I wanted help not sarcasm so if you can’t give me any constructive information then keep your opinions to yourself
Is that still the case :)
Apologies if I have offended you originally , you’ve been a great help I will order another switch and take it from there , while I was checking it I noticed that the pin that pushes the switch seemed a bit tight , could this be a problem ?
