    Dismiss Notice
Difficulty drilling into wall
Discussion in 'Building' started by FestoolFrenzy, 18 Mar 2019.
  1. FestoolFrenzy
    FestoolFrenzy
    18 Mar 2019
    6
    Thanks Received:
    Country:
    Im fitting a bookcase which require lots of holes drilling into a wall at various points. The wall is very inconsistent in density varying from easy drilling to almost impossible. I have blunted flat 3No. 7mm SDS drill bits now.
    Its a bungalow. Using a corded 110V SDS with good quality Dewalt bits.
    What could be behind the plaster that is so difficult to drill?
  2. Sponsored Links
  3. EddieM
    EddieM
    15 Feb 2009
    8,678
    Thanks Received:
    437
    Country:
    Steel perhaps? 110v ?
  4. blup
    blup
    5 Nov 2007
    1,034
    Thanks Received:
    151
    Country:
    Have you tried with another drill?
    A faulty sds drill can give the appearance of working but not deliver the "blows" required
    Blup
  5. FestoolFrenzy
    FestoolFrenzy
    18 Mar 2019
    6
    Thanks Received:
    Country:
    It seems hard enough to be steel but my stud/metal/wire detector picks nothing up, but it doesn't get hard until about 50mm in where the detector wouldn't reach.
    Not tried another drill. I'm pretty confident the drill is fine. Its drilling and hammering perfectly fine. So well in fact that it has flattened 3 bits in this wall!
  6. Sponsored Links
  7. blup
    blup
    5 Nov 2007
    1,034
    Thanks Received:
    151
    Country:
    Fair enough, you're clearly experienced in their use.
    You could magnetise a long screw or piece of steel rod and place it in the hole already drilled to check if it's steel, or chop out around the area.
    Have you tried to identify which parts of the wall contain the steel (beam/sheet?), how high up are they?
    Blup
  8. bernardgreen
    bernardgreen
    3 Nov 2006
    23,008
    Thanks Received:
    2,178
    Bedfordshire
    Country:
    stone, granite maybe
    I have similar problems with the rubble and mortar walls of my cottage.
    Chemical anchors such as THIS and a bit of studding make for very secure fixings. ( use with the correct applicator gun (Code 16539) and nozzles.
    ( Other sources of resin anchor are available.,)
  9. Ian H
    Ian H
    14 Sep 2010
    6,321
    Thanks Received:
    715
    Rochdale
    Country:
    Try an HSS bit in the hole.
  10. ^woody^
    ^woody^
    3 Sep 2006
    28,646
    Thanks Received:
    3,640
    West Mids
    Country:
    You don't tend to get random chunks of steel in a bungalow wall.
    BTW, how many holes does a bookcase require? I'll start the bidding at two.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
