dimmer and extractor fan in bathroom
ogc
25 May 2004
hi
im doing the bathrom at the moment and was wondering about the requirements for fitting an extractor fan with a dimmer.
i know the dimmer needs to be placed outside the room but how does the fan work with it.
im assuming that when the dimmer is clicked on the fan would come on and the dimming would have no effect on the fan.
are there any other regs
i dont really want a pullcord in the room either.
whats the deal with this
thanks
ogc said:
hi
The requirement is don't do it.
Extraordinarily badly, to the extent of being permanently damaged. You can't use an ordinary dimmer on a fan.
What a curious assumption. You can see with your own eyes that the dimmer makes the lightbulb glow less brightly, i.e. it is getting "less electricity", but you think that you can feed the fan with the same "less electricity" and that will have no effect.
thanks
The deal is that you can't use a dimmer switch with a fan. It's nothing to do with the regs. If your bathroom light is dimmed, then you cannot have the fan wired from it in the conventional way, end of story. You'll need a separate switch for the fan, and that can be inside the bathroom, or outside, 'tis up to you. If it's inside, it has to be in Zone 3 or outside the Zones (do a search for [bathroom zone] to find out all about that), and it should be a pull-cord, but it doesn't have to be.
You have some other options, though.
You can switch the fan independently via a fan speed controller (similar in appearance to a dimmer)
Ban - I think you've been a little mean - ogc is 1/2 right.
I know you don't like pullcords, but you can get a pullcord dimmer that has an output suitable for switching fans ie you can dim the lighting via the pullcord, but the fan switches on and off just as it would through a conventional p/c switch.
See tlc TL PCD51 - 17.99 Note - not suited to fluorescent loads.
Ah - didn't read it that he was looking for a fan-speed control option, rather a case of "my bathroom light is (or will be) on a dimmer, can I connect the fan to it?"
thanks
the pullcord dimmer sounds like a winner, il,ll have a look around.
