Dimmer ID
15 Apr 2005
Yorkshire
What make is this dimmer? if it can be identified. Its a standard knob front.
Long time no speak.
Is it an early Varilight?
What is it about the dimmer you need to replicate when you replace it?
Well hopefully you'll see the issue if I tell you one of the dimmers has two 13w LED fittings on it. I did specify trailing edge dimmer for these fittings as they are dimmable. but I never mentioned the rating. the lights buzz and the dimming is all over the place. I just wondered if these were actually trailing edge. bit I guess I'll never know.
That dimmer needs a minimum load of 40VA. It's written on it. Your LEDs are only 2x13VA so not enough. Just buy a V-pro dimmer module from TLC. Simples!
Just wondered if anyone knew what type this was.
You mean whether it's leading or trailing edge?
If you crack it open and post a photo of the innards I can probably work it out!
I may be cracking open at least one of them when I've got a new module for the leds.
