- Joined
- 11 Jul 2017
- Messages
- 247
- Reaction score
- 20
- Country
In my lounge I've got 2-gang 2-way dimmer switches, 1 gang is for wall lights and the other is for ceiling. They are Varilight V-Plus, 1 master and 1 slave unit. I previously had issues with 1 gang (https://www.diynot.com/diy/threads/dimmer-switch-issue.528383/ for reference), and got a replacement.
The wall lights have 4x40w and the ceiling 6x40w, so both well within the power range of this switch.
Unfortunately, the replacement didn't last long either (~ 8 months) as a blown Halogen damaged the dimmer. Varilight have since recommended that I replace the bulbs with a more reputable manufacturer such as Osram, which I have done.
Well, the latest switches were fitted last week, all well and good... until yesterday, when they've started to play up again. Both gangs are showing the same behaviour - if I turn the lights on, they come on dimly for 2 seconds and then turn themselves off. If I cycle the MCB, everything is back to normal and the lights work again for a day or so, when I have to repeat the process. This happened before with the first unit before it completely failed, so I'm waiting for the inevitable now.
I temporarily ran a regular light-switch for a few days in the interim period between broken switch and replacement, and everything was fine.
I am tearing my hair out with this thing and cannot fathom what could be causing the problem. Before I go to regular light-switches once and for all, has anybody got any idea what could be causing these continual failures? I've put a multimeter on various points in the circuit and it all looks good and consistent.
