Diplomat APM 8512 Washing Machine - No Longer Spinning
4 Jan 2008
Hi
I have a Diplomat APM 8512 Washing Machine ( I believe that is a Servis machine ) which is no longer getting up to the full spin speed of 1000 rpm.
I have checked and cleaned the filter - in addition the machine drains normally.
Machine agitates the drum left and right and spins gently :), but not at 1000 rpm.
I understand that this model has an induction motor - so no carbon brushes.
Based on this information could the fault be with the electronic module ?
Many thanks.
Hi
I switched the module for a refurbished module. However with the refurbished module the machine would not even start ?
Any suggestions would be greatly appreciated :)
It could well of been the motor capacitor that has become weak they were common to go on them as for the circuit boards they fitted quite a few different versions so it could be you've been given a wrong version as they appear identical looking at them.
Hi
Many thanks.
Can the motor capacitor be replaced ?
When the refurbished module was returned, I was told that a chip had been blown on the refubished module ???
The capacitor is easy to replace but from what you say a blown pcb is not good news it could well be the motor's blown the board maybe time to replace the machine.
