direct and indirect cylinders
8 Mar 2003
Cornwall
Direct and indirect cylinders
" " " water storage tanks
" " " water service
Do all the above categories have to go together?eg. direct cylinder and water tank and water supply?
A direct tank is the same as a cylinder :wink: holds water @ more than atmospheric pressure, a Cistern holds water@ atmospheric pressure :?
nige, your reply does not make sense, perhaps you would enlarge, for instance a cold water storage tank is not the same as a cylinder. Still puzzled.
Cold water storage "tank" is a cistern....A hot water tank .galvanised steel cube- is the same.ie. it holds hot water-as a copper(or galv. steel) hot water storage cylinder.why do you ask :?: :wink:
Nige F's reply makes perfect sense. What doesn't make sense is your question. Why are you asking about things using terms that are incorrect? Do you have a plumbing related problem, or not?
