Direct and indirect cylinders
" " " water storage tanks
" " " water service
Do all the above categories have to go together?eg. direct cylinder and water tank and water supply?
Cold water storage "tank" is a cistern....A hot water tank .galvanised steel cube- is the same.ie. it holds hot water-as a copper(or galv. steel) hot water storage cylinder.why do you ask
Nige F's reply makes perfect sense. What doesn't make sense is your question. Why are you asking about things using terms that are incorrect? Do you have a plumbing related problem, or not?
