TDBOY said:All doorways have to have a clearance of 1m that are too be accessed by wheechair. You used to be able to fit 926mm doors which are plenty big enough, but now you have to cut them out of a door blank.Just another stupid idea by someone justifying there job.
Presumably you're referring to no non-domestic buildings as opposed to houses which don't require 1000mm wide doors at all!
The reason doors giving access to the disabled in non-domestic scenario's need to be so large is that manual wheelchairs max out at about 840mm wide, when you add on enough each side for a hand you end up with about 1000mm. I'm currently doing a job for a tetroplegic, what size doors do you think he's asked for? thats right: 1000mm.
