Dishwasher Thermo Stat broken
17 Sep 2010
Belfast
Hi Folks
My sisters dishwasher has stopped working, I have found the problem to be the thermo stat had broken off. The thermostat is fine, however the section of it which is in the washing compartment has broken on the thread.
Problem is I don't know what it is called to get a replacement, I have attached an image, its the part on the right which has broken and should from memory look like a brass nipple which sits in the bottom of the tray to measure the temp of the water.
Thanks for any help offered.
The screw on cap part, you will have to ask if it comes complete (some do) or just the stat.
Otherwise you may get away with just a stainless steel nut on it with some Fernox LX sealant
