Dishwasher tripping RCD on fill
1 Aug 2007
Newcastle upon Tyne
I have been using an Ariston integrated dishwasher daily for the last 3 years without a problem, but last night it tripped the RCD. It must have been about 3/4 the way through the cycle and when it tripped there was a strong burning smell. I reset the RCD and turned the dishwasher back on and it tripped immediately. I manually emptied the water that was left in and started a new cycle. As soon as it fills the water to the stage where it contacts the metal of the inside of the washer it trips again.
I've tested the element and that's fine. The pump also seems to be okay (small resistance across terminals). I've not tested the motor yet. There are no obvious leaks in / beneath the washer.
Any ideas what this could be / what else I could check?
Thanks for any help you can give,
Andrew
If it trips your rcd and you have noticed a strong burning smell then my advice is to leave well alone & contact qualified assistance. Electricity can kill :shock:
