DIY Project consevatory/playroom between 3 internal walls
20 Sep 2012
Northamptonshire
I am after some advice i am about to build a very basic conservatory to use as a playroom for the kids, its going to be between 3 main walls so only 1 part will be exposed to the outside weathering. a bit like a U shape.
Its going to be 4m long and 2m wide, then when thats complete i may be adding a further 4.5 m length to it depending on the wifes decision!
So far its going to have 2 main beams of 4x3 timber obviousy 2m wide then there will be three main joists between them all being 4m long.
so basically 2 of the main beam joists will be fixed to the house then 1 main joist in the middle.
Is that going to be strong enough for the roof its only going to be polycarbonate 25mm so not very heavy?
so its basically a lean to roof a bit like a car port. also what is the minimum angle for the water to drain from it? i was thinking about 30 degrees.
Then obviously a concrete base at 150mm and plasterboard batton all round inside. Do i need supporting corner posts to help support the roof or will it be ok just fixed to the walls with decent fixings? bearing in mind i will have to stand on it to flash it after.
Joists 4x2?
end beams 4x3?
plasterboard batton 2x1?
Concrete base a total of 300mm after hardcore damp proof then concrete?
Also shall i do the roof flat and use joist hangers and then use filling timber on top of the joists to put a slight angle for the polycarbonate so it gets the water off?
OR shall i just do the actual main 3 joists at angle?
does anyone think i should use 4 joists instead of 3 ?
ANY advice i can get on this project on sizes of timber and which fixings are best etc will be highly appreciated and listened to, i am not a builder by trade i did plastering and window fitting years ago but never put joists up before so am just being extra carefull and making sure i get everything spot on.
Cheers !
You can buy aluminum profiles that will save all the messing about with timber, one down the middle and one abutment at each side if it is only 2m wide.
ok mate i did look into this, but its about £700 for a complete polycarbonate roofing kit where as the timbers only £97 plus the £196 for the pollycarboanate roofing ahh im not sure which way to do it.
