    Dismiss Notice
DIY replacement of electrics in kitchen, sanity check & questions
Discussion in 'Electrics UK' started by TonyBelfast, 14 Dec 2017.
Thread Status:
Not open for further replies.
  1. TonyBelfast
    TonyBelfast
    14 Dec 2017
    7
    Thanks Received:
    Belfast
    Country:
    Bought a house. Wiring re-done in 2000's, memera 2000 CU. Kitchen has dedicated 40A connection for cooker running outside house, leaving that alone. Only two double sockets in kitchen coming in nasty trunking down from ceiling - 20A. I plan on replacing with a 32A MCB and 4mm core cable as a radial, running in through a wall and in trunking under the counter-top, feeding 5 double sockets, two under counter for appliances, three above for kettle and whatever. I would also like to add a light from the end of the radial into the separate pantry, is that ok? it's nowhere near any lighting circuits. I was thinking of just putting the light on the wall next to a switched FCU with a 5A fuse in?
    I should note this is in Belfast where part P does not apply - but naturally I want the installation to be safe.
  2. Sponsored Links
  3. mwatsonxx
    mwatsonxx
    6 Apr 2017
    785
    Thanks Received:
    50
    Country:
    Sounds good to me.
    • Like Like x 1
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    4mm² is not rated at 32A when installed like that.
    How will you be connecting the sockets to the cable? You may not have the circuit cable run through the sockets as they are not guaranteed to be able to have more than 20A on their supply cable.
    What are you going to do about testing?
  5. winston1
    winston1
    11 Jan 2010
    5,775
    Thanks Received:
    422
    London
    Country:
    Bearing mind what BAS has said why not make a ring in 2.5mm.
  6. EFLImpudence
    EFLImpudence
    7 Jul 2010
    32,091
    Thanks Received:
    3,479
    Retired to:
    Country:
    Portugal
    Don't use trunking, then, just clip it.
    What?
  7. mwatsonxx
    mwatsonxx
    6 Apr 2017
    785
    Thanks Received:
    50
    Country:
    The circuit cable does not run through the sockets. The terminals in the socket (or any other similar device) are for maintaing the circuit connections. As long as those connections maintain the CSA of the conductors there can be no detrimental effects on the socket and the current they are carrying is irrelevant. If it was physically possible to make a connection those cables could be carrying thousands of Amps.
    The only current flowing through a socket is that going through the plug.
    You're not very good at this, are you?
  8. TonyBelfast
    TonyBelfast
    14 Dec 2017
    7
    Thanks Received:
    Belfast
    Country:
    What's this about? Because I was going to put it in trunking? I don't want to make a ring, really. Going up to 6mm seems crazy. I could just clip it to the wall, but that doesn't seem right? It's not going to be visible or anything so I'm very much open to that.
  9. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Yes it does. It loops from one socket to the next.
    Untrue. Try reading BS 1363.
    It seems that I know what I am talking about, and I can read and understand.
    You suffer from considerable handicaps in all those areas.
  10. Sponsored Links
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    BS 1363 does not require any socket to be able to pass any tests of overheating etc with loads on the circuit cable exceeding 20A.
  12. TonyBelfast
    TonyBelfast
    14 Dec 2017
    7
    Thanks Received:
    Belfast
    Country:
    Current plan is to ask my wifes cousin who is a Spark working in Aus, to have a look when he's home for Christmas.
  13. TonyBelfast
    TonyBelfast
    14 Dec 2017
    7
    Thanks Received:
    Belfast
    Country:
    I have no idea what's being said about the sockets. I was planning on following the normal radial circuit diagram, connecting via the terminals in the sockets.
  14. EFLImpudence
    EFLImpudence
    7 Jul 2010
    32,091
    Thanks Received:
    3,479
    Retired to:
    Country:
    Portugal
    The cable will get hotter in trunking so cannot carry as much current.
    It is.
    It will be fine like that.
    • Like Like x 1
  15. EFLImpudence
    EFLImpudence
    7 Jul 2010
    32,091
    Thanks Received:
    3,479
    Retired to:
    Country:
    Portugal
    Surely that is through the socket via two plugs.
    Please see Appendix 15B.
  16. mwatsonxx
    mwatsonxx
    6 Apr 2017
    785
    Thanks Received:
    50
    Country:
    That's not the same as passing through.
    I have read it and taught you most of what you know about it. The only mention of current is a 20A heat test with the 20A conected via the load side.
    It seems you think you know ie guessing again.
    Perfect in all areas. But my main attribute is honesty.
  17. winston1
    winston1
    11 Jan 2010
    5,775
    Thanks Received:
    422
    London
    Country:
    Does he know anything about UK regs? It is different down under. They use funny plugs looking like a crows foot and rated at only 10 amps. They certainly don't wire them on 4mm cable.
Loading...
Thread Status:
Share This Page
