We're currently getting an extension built on the back of our house and the build is almost at the 1st fix stage (roof / windows going on in the next few weeks).
The insulated floor still has approx 25mm of concrete to go onto the top and so there is enough room for the 10mm microbore pipes for the heating system under it.
There is one area of the house which i'm tempted to lay in a coil of 10mm copper microbore pipe down (wrapped in black tape to stop corrosion etc) to increase the heating in this area and then also feed this (in series) to a radiator in the same area (so its switched off via a TRV at the same time as the radiator).
I have still yet to mention it to the builder & plumber but wanted to see what people thought here first.
Thoughts?
EDIT: - Looks like this might be a bad idea because the water in the underfloor pipework needs to be at a lower temperature than the water in the radiators.
Thoughts?
