I had a 9.5kw mira sport shower fitted a year ago by a local company. the isolation switch has burned out.
the company used 6mm wire and a 40amp fuse. is it safe
the company said, because it is less than 15 metres of wire 6mm is fine.
the fuse box had two fuse for the lights, they have put the light onto one fuse and used the spare fuse for the shower. is this good practise.
the company will replace the switch but not the wire, should i be concerned.
