My domestic central heating system is configured (very simply) thus :
two Potterton Suprima 120L boilers connected to the same cold input and common hot output
Grundfos UPS 15-60 pump
20 radiators
pressurised system with TRV on 18 radiators
It's a 5 bedroom house, the boilers were put in 12 years or so ago by the previous owners.
We moved in a few months ago and one of the boilers (to be known as 'the left boiler') regularly trips out, the red light flashes and the green light goes out. According to the manual this is due to a dud thermostat or overheating.
British Gas came round to check over the system as part of the annual service and I pointed out the problem with the left boiler. After taking a look the engineer told me that the problem was overheating and that the pump was not up to the job. He also said that these boilers are recommended to be installed with 35mm pipework rather than the 28mm that has been used. He recommended a pump upgrade and a pipework upgrade. The recommended replacement pump is a Grundfos UPS 25/55
So now I have a list of questions...
is this the right pump? Grundfos say it is obsolete and that the MAGNA1 25-40 is compatible
is it essential to have the pipework upgraded or would the new pump be OK with the narrower bore?
is this simple enough for DIY? I'm fairly competent with DIY and have done a bit of plumbing (compression joints generally )
are there any other suggestions? Someone I know suggested a second pump in series with the first
what else am I missing?
The quotes have come in and now I know how BG make there money! Manpower is 88ph and the pump is available online for almost 1/2 of what BG want to charge!
Excuse my vagueness, if there is anything obviously missing please tell me.
Thanks!
Dave
20 radiators
Thanks!
Dave
