I know Part P applies to electrical work in a kitchen, but obviously there are limits - eg buying a new kettle or microwave and plugging it in doesn't require LABC approval (or does it???
) I guess because of the 3(c) exception.
So, if I was to get an Evoline V-Dock (essentially a pretty looking extension strip for Kitchens) with a plug & cable, and routed the cable through the kitchen work surface to an existing socket behind the kitchen units, would Part P apply there?
What if I get kitchen cabinet downlighters with a transformer with integrated lead and plug (or even a 'kettle' type lead - if it's good enough for a kettle..?) and lighting fittings with integrated leads to plug into the transformer, would Part P apply there?
If the flexible cables are tacked to the walls (behind kitchen units) does that change things?
I guess what I'm asking is if Part P only applies to kitchen work which involves messing with the 'fixed' side of the sockets? Can I do anything reasonable I want which just involves plugging into the existing sockets?
(It would obviously be neater (and probably safer) to have fixed wiring, but for £270 LABC fees, I'm thinking of alternatives...)
ALso, what if I want to put a doorbell in the kitchen? It would be mains powered, but the transformer already exists in the garage, so there would just be an 8V AC supply going into the kitchen. I suppose you could say that the doorbell power supply is 'extra-low-voltage wiring for the purpose of signalling', so it would be exempt under 3(a)?
(The more I look at Part P, the more absurd it becomes
