Do you always NEED threshold strips?
6 Jan 2008
London
I'm about to lay laminate flooring in my living room, dining room and the 2m hallway that connects the two. Is there a reason why I must put threshold strips in both the living and dining room doorways or can I just run the flooring through?
I don't think you need threshold strips, and should be ok to continue through each room.
Does the instructions mention anything?
Thanks for the reply. There's nothing about it in the instructions. I'm just wondering if there's some floor laying gospel that I'd be damning myself to break. "You must have strips or X will happen" type thing.
Not sure about that, but sure someone with more experience will chime in
You can get away with running it through. But laminate expands at different rates depending on temperature an humidity.
So running it through can cause it to buckle in doorways. Seen it happen on a few jobs.
You can buy quickstep Incizo Doortrims which match well an don't stick up to much.
As Dazlight says, they should be fitted, if you choose not to fit them, be prepared to fit them if the floor does move. Undercut the architraves and be sure to allow as much expansion as possiblet o give yourself a fair chance.
Of course, the dreaded expansion issue! I didn't think of that! I'd be laying laminate end to end over some 25 feet so I can see how that's cause for concern.
Thanks for the advice, I think I will put th strips in.
