Hi all,
About a year ago I've got a small toilet-shower installed under the stairs.
Yesterday the shower drain got clogged and I have used some chemicals, hot water and finally a plunger to unclog it. After using the plunger the hole drain pipe has come off . As you can see in the picture it was only hold by silicone and nothing else. I am not a plumber but in the past I have installed sinks and all drainage systems were hold together with a long screw holding top and bottom parts together and silicone only used to seal and not to hold bits together. Is the drainage system in the picture normal?
