Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
~ The TV amplifier is fed by the white T&E between the switch and black connector box. The cable terminates in a socket just before the amplifier
~ The switch box receives its earth down this T&E
Very well, one person has answered the question in the title.
I have described a system I have to assume was installed by someone trading as a professional electrician. Someone, let's remind you that failed to connect earths properly, if at all. So, how do you think it affects my opinion of the trade? In general, do you think the bandwidth used up in this thread has done anything to raise the game? Well, no. Perhaps it's just bluff to make it easier to cover up other mistakes.
What actually happened was that many years ago the original installation was done properly, and then one day the Venner timeswitch (which would have been screwed to the wall to the left of the metal switch) broke, and rather than pay to have it repaired or replaced, some bodger decided to have a go at fixing it themselves using a £2 plug in timer and the flex cut off of an old vacuum cleaner.
When it was plugged in, the fuse blew due to a fault on the lighting circuit (which is probably what damaged the original timer), so the wires were hagged around in various combinations until the lights switched on, and the cables someone decided were faulty were disconnected and cut off.
The only testing done was a bang test, and of course none of it was notified to anyone.
Now someone appears and wants to fix things - but once again wants to do it all themselves after asking people on a DIY forum how to do it, and not pay someone what would actually be a fairly small amount of money to do the job properly.
The original installation had four sheathed cables coming out of the black box. Two have been cut back, only one is now active. Each light had a push button delay switch.
At some point the supply cables rising out of the floor were replaced by those coming out of the trunking. So the object between the switch and black box was probably the original meter.
I do not know whether the two changes took place at the same time. The flats became freehold in 2007 so the modifications would have been made under a landlord and management company.
The TV lead would have been added after original installation - one of the white T&E which finishes at a socket on the 2nd floor, hence the question about the fuse.
It is difficult to ascertain how the box and sheaths were originally connected to earth other than that now they are not. I will speculate that it had something to do with the change of the supply so professional work is not entirely ruled out.
Once again someone jumps to conclusions. It would be nice to know what the changes might look like. You think I would alter the system on the sly without the other flat owners knowledge?
