Domestic 3 way switching
So they've screwed up because they didn't know enough about what they were doing, which is fair enough - people can unexpectedly get out of their depth, it happens.
But then they look someone in the eye and lie to them, and they think that makes them look better?
What a dreadful thing to do.
Yes they do, the bloke that never made a mistake never made owt.
A mistake is evidence that someone has tried to do something.
No one never made a mistake.
Mistake should be rare (each man should know his limitations as Clint said).
always read instructions even though you think you know - Donald Rumsfeld had something to say on that one.
But yes we all make mistakes, admit it, say what you tried to achieve and it might just shorten the investigation and correction process sometime.
Not many will berate you and not by much anyway - usually (Except that fellow who cut a Frogs back legs off to prove his theory!)
In this instance the diagnosis was quite simple, the LAP switch stood out like an artic in a carpark and I found the choc block with the 2 reds twisted together. I nearly didn't open the other 2 switches but not wanting to look a richardhead I did check them before confirming the problem.
I've had lying from customers loads of times.
Trying to get repairs under the terms of the maintenance contract.
One obvious one was a three gang switch where everything was effed up completely.
It was quite plain the switch was brand new yet she swore blind to my face that it had been "like that for the last few days."
Yes it's quite a common reaction when they get out of their depth, I've had a few who have been honest and explained they tried and failed. It doesn't make the diagnosis any easier but it doesn't generate the bitter taste.
The other fairly common thing is decorators saying they'll replace accessories as part of the job and that often ends badly for them. One of those was 2 * 2way & 2 * intermediate in a 4 module plate with something like a dozen cables, one of those where the heavy stomach feeling starts the instant the eyes see the problem.
She wouldn't have known about Live CDs. I honestly couldn't work out what she did. I used a live linux CD to look at the drive- that was when I discovered that C:\WINDOWS directory was missing. First time I had come across that.
In the early days, on my first PC, I somehow managed to do the same thing and had to return it to get a fresh Windows installation.
The seller, a large one at the time, couldn't understand it and didn't blame me, as it should have been impossible for me to do accidentally.
End of last week an employer I hadn't heard from since 2008 called and asked if I could do a 'follow-up' visit.
Story up to that point was customer had removed a switch while decorating and it broke, took it to 'the shop' and asked for a replacement and fitted it, it didn't give the same operation as the original and he swapped wires around then called said employer.
A member of staff had gone out and diagnosed a damaged cable, I'll give him a false name to protect the guilty - Fred.
Customer said he would call when he removed the carpet and could lift floorboards to replace it, rather than calling back he replaced the cable himself but it made no difference.
I was led to be believed there are 3 lights and 2 switches and a congested 6 terminal JB in the cupboard under the stairs. Stupidly I left my phone in the decent trousers I changed out of so a sketch will have to do.
It turns out there are 3 switches and 2 lights, customer described how they had to ensure the top left switch (TL bottom of stairs) had to be up, top right (TR top of stairs and had been replaced) had to be up so that bottom right (BR at bedroom door) could switch the light off and back on for the middle of the night bathroom visits. This required both of them checking/setting them each night.
I was able to buzz out TL and BR but TR was too confused by the other switches - hence the attempt at erasure and I had to disconnect the new cable at the JB. It was connected as shown in colour in sketch above and as found below but to restore the original operation it had to be as shown in pencil below. The only cable with an earthwire was the replacement and that is cut short.
Pink stars represent JB terminals.
The original switch was a 2 way with N terminal (and still in the box of decorating rubbish) laid out like this with original wire colours shown:
and the replacement is an intermediate (remember he asked in the shop for a [4 terminal] replacement). When he put the wire colours in the same physical position (and the N or now called LOOP left unused) effectively that made the yellow the COM and swapping the yellow and blue over made it work as they expected.
I don't think I'd ever come across three 2 way switches incorrectly wired like this before August but now a second within 2 months.
I asked how long it had been like this, he said he was 10 when they moved in there in 1987 and it has always been like it. It's an old house with lathe and plaster wall upstairs with a surface pattress box set flush into the wall. I explained how an intermediate should work and of course the suggestion had to be made... we dropped the original piece of cable (also still in the box of rubbish) back into place (nothing wrong with it BTW) to wire it using conversion method (specifically to use only 6 terminals).
Customers downright lying about what they have done or attempted to do well I can easily accept that but downright lying deliberately or tell a lie inadvertantly because another trade/DIY/relative has mucked it up.
I always make a (mental ususally) note of what they tell me as a first instance position unless its obvious to me that might not be true.
Sometimes its innocent or careless but downright deliberate really irks me.
EDIT - Hm it appears I got distracted and broke off typing then resumed later without checking what I had already written.
Silly me, thanks to Sunray for spotting my error.
Last time I actually remember such aa gaff by myself I was approx 11 years old (yes a few centuries ago some of you might be thinking!) . An excersize in school where we had to pick a game then describe how to play that game.
I was torn between "blow football" and "tiddlywinks" . I started writing it one day and completed it the following day.
When the teacher read it I had written
"To play blow football we have to fire tiddly winks into a cup."
LOL - one I strongly remember (I can not imagine that anyone has ever invented a game of football the begins with some tiddlywinks since then.)
Silly me - ps - I am not claiming that example to be the last time I made such a silly mistake, probably quite a few since then if you add them up.
Anyhow, I will not edit that mistake out I will leave it there to demonstrate my shame at that siily mistake :giggle: :LOL::oops::confused::(
Slightly confusing.
I assume you are saying you're not happy with customers who deliberately lie, as in my August post who was deffo lying.
You are happy with customers to tell the truth, be that the situation, what they have done or tried to do, got wrong etc. Such as my last week who I reckon was as genuine as could be and he's lived there for 40 years with a crappy system. His wife told the same tale of the bedtime routine.
I always take the first comments as correct until it becomes obvious they are lying, such as the new switch in August
Yes I agree and sometimes the bill goes up ;) and sometimes I go the extra mile such as pulling the original cable back in last week (which was actually very easy with his help and only 2m long) to make into a proper intermediate system. Also if I'm not the first to look at the problem I'll try my very best to make it as right as I can, within reason.
...Silly me - ps - I am not claiming that example to be the last time I made such a silly mistake, probably quite a few since then if you add them up.
A man oo never made know mistooks never made nuffink.
