Hi
can you tell me if there should be a minimum or maximum water presser coming into a house? as i Had a gas man out to see about getting a new boiler as the one i have was not working that good (i have just moved into this house)but the guy said it was the water presser not the boiler, pressure is below 1bar and i need about three times that for the boiler to work at it best (it takes about 3/4 hour to run a bath)
Also that we had lead pipes coming into the house, would this be a costly to change
Any help would be appreciated
