don't have planning permission-what to do next?
29 Jun 2010
Northamptonshire
I've bought used conservatory and when preparing base for it realized it's to big :eek: and I should have a planning permission...
It's 4.2m x3,75m...
So what should I do next? Where should I start?Stop the works and start with the permission?How long does it take? Will I have to wait till next summer to built it?
What if I continue? What penalties will apply?
Planning normally takes about 8 weeks all in.. sometimes a little longer depending on neighbours responses..
You might worth a quick call to your planning officer and asking if the size is under permitted development or not, as its alot quicker to get a cert rather than go a full app route..
Better to hold fire till you talk to the planner..
A Certificate of Lawfulness also takes eight weeks, so the same time as a normal planning application.
However, the process is a little "easier". I've done three (successful) applications now so am becoming quite custom to them :LOL:
Thanks for that...I'll try to book appointment with local planning officer...
One more question: when I'll apply for planning permission to build this conservatory, can I include heating in it (I would like to have conventional radiators and boiler heating) or do I need to apply for something else?
All I meant was that heating, etc... would come under Building Regulations and not Planning... but I don't know why you'll be unable to connect the new heating to the existing system :confused:
You can install radiators connected to your main system as long as you have controls in place that can isolate them effectivley from the main system.
Pete
