Door closers, required or not 2012
16 Jun 2006
London
Hi all
My client has a 5 story, single occupancy town house, built in Hammersmith in the late 80's, non-networked (battery only) fire alarms. There have been no significant alterations to the property since it was built, ie no attic conversions, etc.
Each of the bedroom doors has a door closer. At some point each of those doors had yale locks as well so I suspect that it was once a multi-occupancy home.
The room that I am currently redecorating has a balcony, if that makes any difference.
Is it OK to remove and bin the door closer or they still legally required.
I did look through some of the older posts on this site that suggest that it would be ok but I just wanted to double check.
Thanks.
They need to stay, as they were required as part of the regulations at the time of construction
thanks woody.
I did phone building control before seeing your reply. He suggested the same kind of thing but said that being a single family household they probably aren't necessary anymore but only a fire inspection would prove definative. He didn't seem concerned about its removal.
I suspect that the client will decide to do away with them, at the moment the doors have wedges to keep them open anyway. I shall recommend that she upgrades her fire alarms though and I will use Red Devil one time to fill the holes so that the closers can easily be replaced.
TBH I don't know if they were fitted at the time of building or when the previous occupant rented out rooms.
Tnx again
In a private residential (dwelling) building door closers are required when it contains a habitable storey with a floor level which is more than 4.5m above ground level. The reference for this is Building Regulations Part B, Volume 1, Appendix D. (Page 68) See this link:-
http://www.planningportal.gov.uk/bu...approveddocumentsb/bcapproveddocbvol1/volume1
Door closers DO SAVE LIVES, see link:-
http://www.
http://www.
But that would imply that anybody who has a loft conversion done needs door closers. I'm pretty sure I've had that conversation with my BR dept and they said nothing about needing door closers
http://www.
The poster is confused. The only place a door closer is required is between a house and an integral garage. They used to be a requirement under Part B but were dropped in the last edition.
