Hi I have a stud wall to plaster, put in doors and linings and fit plaster boards over.
I am using standard 95mm x 45mm timber studding, I will put one layer of 12.5mm plaster board each side on one wall, and one wall with 12.5 plasterboard one side and 2x 12.5 boards the other.
I cant work out what is the correct casing depth to use:
95x12.5+12.5=120mm
and
95+12.5+12.5+12.5 = 132.50
My builders merchant only sells 115 and 140mm depth linings, am I meant to plane the 140mm down to fit ?
95x12.5+12.5=120mm
and
