- Joined
- 24 Jan 2019
- Messages
- 121
- Reaction score
- 0
- Country
I'd appreciate some advice or pointing in the right direction. The old wooden back door of my garage is rotting away. The aperture in the brickwork that the door and frame fits into is 36 inches wide by 79 inches tall (915mm x 2007mm).
I cannot find a door and frame set off the shelf to fit in this aperture. The closest I can find are steel security door sets that are available with expandable frames that can be adjusted width-wise, but they are all already too tall (2075mm). There's not any obvious easy way to make the existing hole taller (only two layers of brickwork at the top, and solid concrete at the bottom). UPVC is double the price of steel, presumably a lot less secure, and doesn't come in the right size either.
Is there something I'm missing? I'm looking for an easy, reasonably-priced solution. Is there one?
Cheers.
Cheers.
