Door suitability and type
S
SaladFingers
I'm looking to buy/have fitted a door on the side (not main door) of my garage but would like information on what's best to go for in terms of security, even suggestions.
uPVC?
Composite?
Aluminium?
Wood?
Which is the best and why? What do I need to look out for with regards to security?
1 Dec 2009
South Yorkshire
Barbados
For a side door to a garage you'll just need a solid door, no need to weaken it with glass so i'd fit a hardwood frame and a solid door blank and a 5 lever BS mortice lock.
And if security really is an issue then i'd have the door opening outwards so it can't be kicked in, i'd glue/screw/bolt a galv steel sheet over the door and i'd cover the frame around the lock keep with a strip of steel, also fit 4 hinge bolts
W
Workers
For about the same cost a locksmiths or local metal works could make up a steel door and frame.
S
SaladFingers
I'm not so sure about wood, with the swelling, paint maintenance etc.
1 Dec 2009
South Yorkshire
Barbados
uPVC?
Composite?
Aluminium?
Wood?
Well you did ask :rolleyes:
In order of preference regarding security and why........IMO
Timber.....................see above
Composite........Strong door slab(if not glazed) if you choose a timber core type as opposed to foam, can get some good locking mechs now or even with 5 lever mortice, timber or pvc frames available
Pvc................Needs to be a good quality and fully reinforced and a BS approved locking mechanism, impact absorbant to a degree but weak points will be the welds and the glass or pvc infill panels
Aluminium.............Strong frame but box section ali prone to crushing and bending upon impact, glass or infill panels can be smashed or kicked in as per pvc
S
SaladFingers
Alright, I want hardwood.
Things to look for, ask for, tips and stuff?
