Door threshold draught strip
28 Jun 2005
I'm after a strip with a raised D in rubber that the bottom of the door will sit on - directly under the door, doesn't need to be weather proof, just draught proof. Is there a special name for this.? I keep finding fancy setups that raise the floor level - I need it to be flat - ie. no trip hazard. Thanks in advance.
An alternative might be to inset an acoustic seal into the bottom of the door. There are also drop seals made which screw onto the face of the door (response added for completeness)
