Socket boxes are 25 mm deep, and the conduit entering them is 20 mm diameter.
The wiring has been run continuously in conduit through the floor (which has now been poured with liquid screed) and then up the walls.
The original finished wall build-up was planned as:
25 mm socket box fixed directly to the wall
10 mm dot-and-dab adhesive
12.5 mm plasterboard
3 mm skim coat
Total build up 25.5mm
I’ve now realised this won’t work, as the conduit will clash with the wall build-up.
What are my options at this stage?
Cut the conduit off at screed level and chase the wall so the socket boxes and conduit can be recessed further back?
Or
Increase the dot and dab depth to around 20 mm, followed by:
3 mm skim
Total wall build up would then be approximately 35.5 mm.
3 mm skim coat
Or
3 mm skim
