Somewhere in the back of my brain is a college lecturer says "do not tin flexible conductors"I will often double over and tin
It's not strictly necessary, but it does increase the CSA of the cable for the terminal screw to bite down upon.
If I am wiring up small conductors, then I will often double over and tin before making the plug top secure, but that is my personal decision and choice.
Well in that case I'm forgetting the same stuffSomewhere in the back of my brain is a college lecturer says "do not tin flexible conductors"
It creates a hard edge to the multi strand flex and makes a place where the cable will break.
Probably why they invented these
But I'm getting old and may have forgotten some stuff....![]()
Correct...If the cable grip has been securely tightened, the cable inside the plug top should not be able to move and break; if it does, then IMO the plug has been poorly fitted.
Then what?Buy good quality plugs.
Have you ever used a plug where the pins don't move?Then the pins shouldn't move about.
Good quality plug tops such as the MK 646 has captive pins which is why they are my plug of choice.Have you ever used a plug where the pins don't move?
