Downdraft Extractor Fan
2 May 2007
Hi
Putting together a kitchen and on the island we have a Faber Fabula downdraft extractor fan, one of these things that goes up and down when you are using the hob on the island.
Looking at the instructions, I thought I was buying something that did just that, rise up and down and used charcoal to collect smells/grease etc which needed to be cleaned whenever necessary.
Looking at the unit, there is a massive ducting part which connects to it, which you then have to duct inside the island and then cut a hole in the island wall to vent outside of the island.
I was really under the impression that this was not necessary, anyone else have one of these? I could really do without having to cut a 120mm hole in the side of the island
Unless it's a cleaning heavy recirculation only extractor - you are meant to go down through the floor or other adjoining hidden area.
Ensure you use rigid or semi rigid ducting of the correct size, avoiding joints when possible.
With most of these the vent outlet will be able to installed either directly down, left or right by rotating the box - so the best installs will be directly down, to a 45 in the floor, then another 45 to the run to the outside.
If it is recirculation only then you will need somewhere for the air to expell from the island easily.
Recirculating units do not comply with current regs which require external extract on new installations.
Hi
You use the word "extractor" to describe this device.
If it does not extract, it is just an expensive kitchen ornament.
I do have an extractor in the wall to comply.
What i need currently is a decent looking output vent I can place on the outside of the island, not too sure whether to go out the side or below it and then out through the plinth piece (150mm). The pipe is 120mm so this is possible, just need some sort of thing that would convert a round flexi duct into an oblong, is there such a thing?
Many thanks, i think i will make a hole in the bottom of the cab then out through the plinth at the bottom, hopefully will not be seen. Question though, the hole in the unit is 150 and i have a reducer taking it down to 120mm. What size pipe would i need to go on these? brain is saying 120mm and then use tape to get it onto the 100mm end?
That will dump damp air and grease on you floor, making it wet and greasy.
