Downlight suggestions
6 Nov 2011
Kent
The OH has decided I'm allowed to decorate the loung.
I'd like to get some downlights installed, but it's been about 10 years since I did any major renovations. Back then I got some cheap crappy things from Screwfix.
I'm looking at LED lights but wonder if anyone has suggestions on what I should be looking at.
Do I go for LED or Halogen?
Mains or low voltage?
I'd like to Dim them if possible but this isn't a pre-requisite.
27 Aug 2003
London
If as part of the decorating you have the opportunity to repair the ceiling, seize it with both hands and put in some lights which are actually meant to light up rooms.
6 Nov 2011
Kent
Light isn't an issue, we have a south facing loung with a nice big bay window.
If the Mrs had her way, we'd have a ruddy great chandelier, however I plan at some stage to put a project and screen in, so said chandelier would only get in the way.
27 Aug 2003
London
Do you get light in the room from it at night time?
There is an awful lot of middle ground between ruddy great chandeliers and little torches embedded in the ceiling.
6 Nov 2011
Kent
Why don't you?
I'm sure there is, but as the title suggests, I was looking for suggestions regarding downlights. Not what middle ground there is between ruddy great chandeliers and little torches embedded in the ceiling.
I assume you're not a fan of downlights, fair enough. Though if you have nothing constructive to contribute I would suggest not contributing at all.
3 Nov 2006
Bedfordshire
Downlighters can be OK but great care is needed when choosing them
[a] choosing where to put them can be a compromise between where the light is needed and where the lamps can be fitted. Joist etc get in the way.
safety of the room above. In many homes the plaster board holds fire away from the joists long enough for people in the room above to realise there is a fire and escape before the floors collapse or floor covering strats to burn. Downlights can and have allowed fire to penetrate to the joists and/or floor boards above. It isn't always the heat from the lamp but that from a fire in the room.
8 Sep 2011
Warwickshire
