    Dismiss Notice
Downlighters with larger(longer) clamp springs
Discussion in 'Electrics UK' started by STI, 31 Jul 2011.
  1. STI
    STI
    5 Aug 2009
    426
    Thanks Received:
    27
    Birmingham
    Country:
    Does anyone know a brand of downlighters that have longer than normal clamp springs.
    Some downlights in a basement are basically falling out of the ceiling. When i inspected them the holes have been ripped ragged everytime someone changesthe lamp. I think the reason for this is that the ceiling was boarded over so it is now two ceiling depths thick and the springs arent locking down flat when pushed in the hole and its basically wedging the light in place rather than clamping it. So everytime its removed its tearing another bit of plaster board from round the edge and likewise everytime its put back in. Someone has actually placed sealant around the rims to keep them in.
    Rather than lift the now renewed,and painted floorboards to get at the light i thought if someone knows a brand of lights with longer springs this would do the trick. Sorry forgot to add the basement room is in fact a bathroom so i would like IP65 rated lights.
  2. Sponsored Links
  3. sparkticus
    sparkticus
    11 May 2011
    1,002
    Thanks Received:
    85
    Bath
    Country:
    I know what you mean but I do not know of an off-the-shelf solution.
    You may need to get creative with some wire coat hangers or something similar.
    You could enlarge the hole and use these: http://www.tlc-direct.co.uk/Products/MLHCW.html
    The root cause of the problem (apart from the double boarding) seems to be that you have to take the whole unit out of the ceiling? Why? is it to change the bulb? Do you really need IP65 lamps? How high is your ceiling?
    Why not replace with LED or CFL bulbs that offer much longer lifetimes.
    • Thanks Thanks x 1
  4. securespark
    securespark
    11 Jan 2004
    37,151
    Thanks Received:
    1,290
    Country:
    Longer retaining springs do exist. Try somewhere like WF.
    • Thanks Thanks x 1
  5. 333rocky333
    333rocky333
    12 Jan 2008
    8,426
    Thanks Received:
    902
    Essex
    Country:
    There are some that use a built in spring to the supporting arms above the ceiling as opposed to the ones that are tensioned by the legs that force against the rim of the hole.
    It is them legs that tend to rip apart the board.
    Try auroura as im sure they do some though it may vary per style and you may need to see them in person to clarify.
    • Thanks Thanks x 1
  6. STI
    STI
    5 Aug 2009
    426
    Thanks Received:
    27
    Birmingham
    Country:
    Your right about the root cause but i can hold my hands p and say not me guv, a handyman used to come in and do it. I want to go CFL and wanted to use the click with megaman units. I like IP65 a because its in a basement with a living room and floorbaords above and b they have the little silicon seal around the light which helps prevent condensation/moisture penetration into the void. nI looked at the TLC converters but they specifically exclude bathrooms. I found others for bathrooms but they are £26 a pop.
  7. STI
    STI
    5 Aug 2009
    426
    Thanks Received:
    27
    Birmingham
    Country:
    Thanks but WF is ?
  8. sparkybird
    sparkybird
    19 Jan 2005
    1,171
    Thanks Received:
    41
    Country:
    WF is an electrical wholesaler (nickname 'wait forever')
    TLC do JCC down lights which have and adjustable slot for the springy arms - you can move them up so that they will grip onto a double thickness ceiling
    You can see it on the pic here
    http://www.tlc-direct.co.uk/Products/GUFRD11W.html
    • Thanks Thanks x 1
  9. STI
    STI
    5 Aug 2009
    426
    Thanks Received:
    27
    Birmingham
    Country:
    Do all the JCC range have these adjustable positions. The idea looks perfect unfortunately the hole is about 70mm and that one is 62mm. I note there are others in the TLC catalogue but i cant see the clip holders.
    Thanks for the pointer a great help
  10. Sponsored Links
  11. Monkeh
    Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
  12. sparkybird
    sparkybird
    19 Jan 2005
    1,171
    Thanks Received:
    41
    Country:
    I suspect so, but maybe worth a call to jcc or TLC first to check
    SB
  13. STI
    STI
    5 Aug 2009
    426
    Thanks Received:
    27
    Birmingham
    Country:
  14. sparkybird
    sparkybird
    19 Jan 2005
    1,171
    Thanks Received:
    41
    Country:
    STI - let us know the outcome ie what worked in the end, it'll be useful for future reference
    SB
    PS Nearly typed STD there.... Freudian slip, eh??
  15. STI
    STI
    5 Aug 2009
    426
    Thanks Received:
    27
    Birmingham
    Country:
    Just once you catch something just once and the whole world knows :)
    I will let you know the outcome once the go ahead is given.
    Thanks for your help
  16. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    [​IMG]
  17. securespark
    securespark
    11 Jan 2004
    37,151
    Thanks Received:
    1,290
    Country:
    Speak for yourself!!! ;)
Loading...
Share This Page
