Downlights
Do you really need fire hoods?
Are you in a standard domestic house, or is the ceiling part a fire rated compartment?
They are in bedrooms with loft space above. I thought building regs required them to be fire rated or with hoods? I could be wrong though.
If it is just a normal ceiling between a bedroom and the loft, fire hoods are not required.
Many electricians fit them as standard because they have been told by the manufacturers who make money from selling them that they should, without actually reading any of the litrature which documents when they are and are not required.
It is an added expense which is simply not required in your case.
More in our wiki
http://www.diynot.com/wiki/electrics:lighting:firehood
It seems the IET have disabled the link to the article in wiring matters at the end of the wiki page. (Issue 14 from spring 2005)
Does any one have a copy?
That really helps. I might just use teracotta pots to keep insulation away or the hoods pending on cost. My last sparki installed them and I could smell something strange, when I went in the loft they were burning the plastic of the insulation away. Hence I soon got another sparki to complete the job.
Im thinkin of having four downlights and a central light in bedroom 1&2, and just downlights in bedroom 3 (box rm) and downlights in landing area. Should look ok I think!?
