I wanted to rule out a faulty new sink mixer tap...ie. when you open the hot tap they could be a possibility that water is drawn across the mixer from the cold side and an insufficient amount from the hot pipe.
The manual indicates the boiler should come on with a flowrate exceeding 3 litres/min.
I would check the cold inlet valve under the boiler is fully open and if so check the turbine and the combined filter and flow limiter in the turbine inlet connection. Probably worth pulling out the flow limiter and blowing through the turbine to check it spins freely.
I don't know any combi boiler that needs 4 l/ min + to trigger a demand for DHW .
You need to establish ....
1. Why your flow is so poor.
2. Why your boiler doesn't fire up with the flow you have ,when clearly it should .
As Gasguru and I have pointed out ,the parts within the boiler that can affect the flow to the taps ,and their correct functioning to activate the boiler ,need investigation.
What is the flow rate of cold water only from the kitchen tap ?
Boiler manuals can be downloaded from various sites.
Probably best left to an engineer.Thanks Gasguru, but I'm not sure Im qualified to take out the flow limiter. Is that something I could do easily?
Altering the flow on the cold to the tap ,without any pressure change ,can't really make any difference to the boiler firing up. Are you really Anti the idea of getting an engineer to visit ?Hi Terry,
The Guy who fitted the kitchen mentioned that I had poor mains pressure, so I've no idea how that could be fixed. I don't think I have any control over the pressure coming in. I am getting a decent flow out of the shower upstairs, but its DEFINITELY not getting as hot as it used to. I used to have to have it resting on it's limiter on the thermostat, but now I have to turn it right the way up to get it hot enough, and even then its lukewarm.
I'm just thinking that the boiler must be just worn out and is giving up the ghost?
The flow rate from the cold side of the mixer tap seems a bit stronger than the hot side, so I've adjusted it on the isolator so the cold is now a bit LESS than the hot, and to be honest it appears to have made a difference. The boiler seems to be kicking in every time I turn the hot side on now. I'm not sure if this is just a fluke, but honestly it seems to be kicking in every time now.
It's very probably just luck though, and bugger all to do with what Ive adjusted.
Tried that earlier ,boiler still didn't fireTurn off the isolater to the cold side of the tap try it then. Faulty tap if the boiler then fires up.
