    Dismiss Notice
Drain block disaster
Discussion in 'DIY Disasters' started by MMutch, 7 Apr 2021.
  1. MMutch
    MMutch
    7 Apr 2021
    Thanks Received:
    Country:
    Hi all,
    We have had a funny smell in the house for a while and couldn’t find the source. Finally checked under the house only to find a big puddle of water under the floor.
    got a plumber out who found that the outside drain was blocked and due to a cracked drain gully the excess water was going back under the house.
    Now this is the drain from the kitchen including the dishwasher, so all the food waste was being dumped under the house.
    the smell then got worse as the water dissipated with the drain unblocked, leaving the waste. I have been under the house and managed to get as much of the waste as I could and disposed of and the smell has gone but I am worried that it might get worse again.
    Any thoughts on what could be done to clean or disinfect below the house would be much appreciated.
  2. Sponsored Links
  3. 600rob
    600rob
    10 Dec 2009
    627
    Thanks Received:
    14
    Middlesex
    Country:
    Assuming the root cause has been fixed then it should be fine
    However if you wanted to disinfect just in case then a 50/50 dilute solution of standard household bleach with water applied with a pressure sprayer would be the first thing i would try.
    Failing that you could try something called BAC-50,its a biocide and general purpose disinfectant that needs to be diluted with water.
    It goes along way when diluted but costs about 15 quid per litre though so id try a bottle of household bleach for a couple of quid and see if that helps first
    Dont forget to wear gloves/mask/goggles when applying either
    • Thanks Thanks x 2
Loading...
Share This Page
