Drain cover under decking! HELP!!
1 Dec 2004
Hi everyone.
I have recently moved into a semi detached house built in 1950. I have recently had a blocked sewage drain. We called Dyno Rod out and they cleared the problem however they suspect there is a colapsed pipe somewhere in the system. They are going to use CCTV to establish. They also said that there is a drain underneath the decking area and i have to remove the decking around the cover as there is no hatch access!!!
The only problem is i dont know where the drain cover is! Does anybody know how i can pinpoint the exact location without ripping the whole decking up?
PS whoever laid the decking also nailed everything in place!
Thanks In advance
use the previouse and next manhole to get the the line and any manholes to the side to help show your where the intersection are likley to be
if you have a stud finder try that
or a lot off prodding with a pointed rod
worth checking with your water company for plans
Thanks for the answer.
Never thought of the water board for plans! I was going to try the council!
Is it likley that the people who built the decking would have covered the manhole with a layer of topsoil?
Thanks again.
anything is possible when people are stupid enough
what can you see under the deck earth 'gravel'grass'weed suppresent plastic !!!
